trouble shifting "04" 400 artic cat??
Old 01-23-2006, 08:10 PM
bongload's Avatar
Default trouble shifting "04" 400 artic cat??
I was wondering why when I get down like in a hole with my 400 cat it doesn't want to shift in reverse?? I have a very hard time doing this unless I rock it back & forth..etc..any one else have this problem??Thanks!
Old 01-23-2006, 08:35 PM
v2rider's Avatar
I have a 06 650V2 and have to do the same thing. I just think its the way they are or mabey it will loosen up later on
Old 01-23-2006, 09:06 PM
Bear4570's Avatar
Engine on or off? If off, that's the nature of the beasts. If on (running), the idle speed is too high.
Old 01-23-2006, 09:35 PM
bongload's Avatar
It's when the machine is running.I had the idle checked & they said it was wright on?? I guess it might just be the way the machine is? Thanks.
Old 01-23-2006, 10:58 PM
rango726's Avatar
i have an 06 400 auto ive had it two weeks and mine does it too dealer says its normal give it some time
Old 01-24-2006, 12:18 AM
Bear4570's Avatar
Right on what? Idle speed spec covers about 100 rpm and if you are at top high end, hard shifting. At the low end, problem solved. So idle "right on" would mean not much help if you are "right on" at 1350, but a lot at 1250. Mine had a 1000 miles on it and was still doing it, back the idle speed down about 100 rpm and problem gone.
Old 01-26-2006, 08:13 PM
LIL57JON's Avatar
We have the same problem with our 400A and 500A. Definitely turn the idle down helps. Also heard the same from the dealer. Have over 1000 miles on the 500 and plowed with it 6 times+ this winter. Still sometimes have to figit with it to get in Rev.
Old 01-26-2006, 09:33 PM
Catterman's Avatar
Got Milk!
Blaming Guns For Crime Is Like Blaming a Spoon for Rosie O'Donnell being Fat!
Depends on how many miles you have on it too, those 400's need about 500 miles or so to be broken in. When I had my 04 400 to get it in reverse I often had to give it a little bit of gas. Worked every time. Good luck [img]i/expressions/face-icon-small-happy.gif[/img]
Old 01-26-2006, 09:48 PM
v2rider's Avatar
Thats exactly what I do. Give it a little gas and it works. I tried adjusting my idle and have it at about 1100 rpms. Any lower and it doesnt stay running all the time when you first start it.
Old 01-26-2006, 11:57 PM
rango726's Avatar
just got mine back from the dealer after its break in tune up and dont know what the dealer did but i can shift mine with 1 finger now. huge difference
Quick Reply: trouble shifting "04" 400 artic cat??
