Problems with reverse and low range
Old Feb 28, 2006 | 09:21 PM
skidaddyrickus's Avatar
Default Problems with reverse and low range
Often I have problems shifting into reverse or low range on my AC 500 auto. It makes a clicking sound as it's not fully engaged. It only has 150 miles on it, so I'm thinking it still may be a little "stiff". It often happens when the bike is fully stopped which I don't understand. Is this a common problem? Is there something I can adjust to improve it? It's not getting any worse, but I'm afraid it may lead to bigger issues down the road.
Old Feb 28, 2006 | 11:50 PM
WhoDatInDaMud's Avatar
Mine would do that going from low to high or reverse to neutral. The remedy was to over shift - ie low to neutral to high or out of reverse to high then nuetral. After a few hundred miles (300ish) it quit doing it. Being new and tight was what my dealer told me when I inquired.
Old Mar 1, 2006 | 08:50 AM
Muddedprairie's Avatar
Try adjusting your shift linkage?
Mark
Old Mar 2, 2006 | 12:08 PM
wideopenrider's Avatar
My 03 400i would do the same thing when i tried to go from low to high, i'd have to shift from low to nuetral then back to high. so it would all of a sudden slam into gear, but it didn't bother me enough to matter.
Old Mar 4, 2006 | 04:34 PM
NevadaCat's Avatar
Your idle may be set too high. That was the problem on mine. Dealer fixed it.
Old Mar 4, 2006 | 05:02 PM
v2rider's Avatar
I also have to adjust my idle per weather (hot, cold) to a lower idle or it "grinds".
Reactant
Mar 30, 2022 02:08 AM
hugemoth
Jul 20, 2020 03:28 AM
Nondem
Feb 22, 2020 12:20 PM
Scottma518
Jul 10, 2015 12:42 AM
bikedad3
Jul 2, 2015 02:15 AM
