No oil in the rear drive
Originally posted by: swampyjunior
Check with your dealer first but I believe the fluid level in the front and rear differential should be 1 inch below the threads. Not to the bottom of the threads like you would think. This may have changed since 2003.
I am not sure if filling the fluids is part of the "dealer prep fees" or not. The dealer I originally purchased my machines from did not charge for that.
Take it to the dealer and have them look at it. That way if it IS a screw up it will be documented.
However, I believe it says to check all the fluid levels prior to riding the machine in the owners manual. So even if it is their screw up they could turn it back onto you.
SJ
SJ
In Large Black Bold Print
“CHECK ALL FLUID LEVELS BEFORE DELIEVERY TO CUSTOMER”
Shonk
Dont overfill it, or you can blow a seal. I would just stick to the reccomended 8.3 oz, and like Catterman says, its a good idea to drain it, and use Amsoil synthetic oil in the front and rear. I did it to mine twice now. (Once at the 100 mile, and again every 750 miles, probably overkill, but i like to take care of it)[img]i/expressions/face-icon-small-happy.gif[/img]
SixSpeed5
8
08-02-2015 05:38 PM
