leaking c.v.boots-advice needed
Has anyone had a problem with grease leaking out of the c.v. boot where the metal clamp is? I have a 2000 a.c.300 there is grease leaking on the right front axle where the boot is clamped on the large diameter side of the axle. there are no cuts on the boot. I went to the dealer and was told you can't buy just the clamp, have to buy a complete boot kit. Also wondering how you replace the lost grease, is there a grease fitting on the c.v. joint? or do you just pack grease inside the boot.
thanks for any help
thanks for any help
armpump450r
Technical and How-To Articles
04-01-2017 06:11 AM
YamahaBoi
06-22-2015 08:11 AM
