High or Low
Old Jan 23, 2007 | 07:03 PM
  #21
weez440's Avatar
Default High or Low
catdude you will probably be fine. like bear said if you get in rough terrain use it. in the gravel pits to where it will suck the power down or in a cultivated field then use it, but on a grass trail i wouldn't worry bout it. the 500 is a good machine you shouldn't have to knock on wood for having good luck with it.
Old Jan 23, 2007 | 07:29 PM
  #22
stihl's Avatar
Default High or Low
I know I am going to change my riding habits.
Old Jan 24, 2007 | 10:48 AM
  #23
jkane13's Avatar
Default High or Low
I ahve a 00 300 and it has 3 ranges. I usually leave it in mid range. Low range is for dragging through long mud holes! High is for only flat hard surfaces. Even rolling hills on a hard trail, it bogs down bad in high range. I am always afraid bogging down like that will cause the clutch to slip and get hot. So medium works best for me.
Try high range first, and if the engine is working to hard, go to low instead.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
fredrikrosen
Sep 28, 2015 09:58 PM
r1pilot83
Sep 27, 2015 07:38 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
