2005 650 Brake lights
Old Mar 13, 2007 | 12:17 AM
apowder97's Avatar
Default 2005 650 Brake lights
For some reason my brake light stays on and will not go off. If anybody has any ideas it would be great.
Old Mar 13, 2007 | 12:30 PM
Chumley's Avatar
It's likely that your foot brake is not returning fully to the disengaged position, mine does it too. I haven't fixed it yet, dunno if it needs a fresh little bend or a different spring or what.
Old Mar 14, 2007 | 10:27 PM
cat4life's Avatar
Yeah, I had the same problem. It is the return spring they put on the foot brake. It is not strong enough to pull the pedal/lever back up to the brake light switch. I went to an auto parts store and bought a dual spring carburetor return spring. It is a spring with in another spring. It has good pull. I took the cotter pin out of the pin that attaches the brake actuator to the connecting rod of the brake pedal. I then put the one spring end through the hole and the other spring end around the connecting rod. I then drilled a small hole on the bracket that is welded to the frame that supports the running board/foot peg.
After I did this mod it has since not happened again.
txpedsrt1
Feb 3, 2017 08:07 PM
DeFox500
Jul 26, 2015 06:32 PM
tporath
Jul 11, 2015 12:31 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
Shifts
Jul 3, 2015 07:59 AM
