towing in reverse
Old Mar 5, 2008 | 11:26 PM
dk1ben's Avatar
Default towing in reverse
I have been pulling fence down on my farm. It is pretty muddy so I have been using my atv instead of my truck. It is a 2006 Arctic Cat 400 TBX auto. I have a Warn winch on the front. I attach the winch to the fence and then pull in reverse.
Do I risk hurting the atv by doing this? I have never owned an atv before so thats why I ask. Thanks for any help.
Old Mar 6, 2008 | 05:08 AM
IdahoVinnie's Avatar
You risk damaging the "drive train" mechanism of the winch. It's not designed to be used as you are doing. I would use a seperate chain (or cable) that is attached to stable part of the atv.
Old Mar 6, 2008 | 09:04 AM
dk1ben's Avatar
ok thanks. i kind of had a feeling that i should not of been doing that. thanks
Old Mar 7, 2008 | 02:37 AM
swampyjunior's Avatar
As was stated by pulling with the machine in reverse and using the winch you will damage both. The winch is not designed to be used in that way. I would think that as long as you did not give it a bunch or really hard jerks it is OK.
I sometimes put my machine in reverse and give it a little throttle when pulling another machine out if I start to slide forward and cannot tie or chain my machine off to a solid place. But I let the winch take up the slack not me going backwards to keep from jerking on the winch too much and busting stuff.
I pull small stumps out with a chain and I attach it to the hitch on my 4 wheeler and drive forward and give it a good yank. Make sure you throw a gunny sack over the chain in case it slips off or comes loose because it really hurts when it hits you in the back. I do not let the tires spin much though as it just tears up the ground. I sometimes have to do some more digging by hand and cut a side root or two to get the job done.
I think pulling in reverse can be harder on an automatic transmission due to the rev limiter. I was told that once and I am not sure if there is any truth to it or not but it sounds logical.
Good luck with the fence.
SJ
Old Mar 7, 2008 | 10:12 AM
HeftyLefty's Avatar
I'll chime in and say instead of pulling in reverse, pull going forward. And wear a helmet, chain in the back hurts. Chain in the back of the head, can kill you. Ain't nothing you're doing worth dying for.
lonerider856
Oct 13, 2023 03:45 PM
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
