EZ-GO Golf Cart pulls an ATV!
Old Aug 11, 2008 | 10:01 AM
bobpo's Avatar
Default EZ-GO Golf Cart pulls an ATV!
I have a 2004 AC TRV 500. 475 miles total since new. I've had it in the shop several times trying to locate a stalling problem. Normally it starts and runs great, but occasionally it will start fine but only run a couple of minutes and then stall. Once it stalls, it will not start for a couple of hours. Then it will start fine again. I've pulled the carb and cleaned it, everything seems great, until it decides to stall again. Fortunately I have a 1964 EZ-GO golf cart to pull it back into my garage. My wife is tired of pulling me back. Any help will be appreciated.
Old Aug 11, 2008 | 10:26 PM
arcticcatdad's Avatar
Try the Coil. I have seen the coil get a little warm and not work for a while. Just happened to one of our 90dvx's It ran fine and quit. Next day fired right up. I replaced the coil and it works great now.
Old Aug 12, 2008 | 12:44 AM
coal dirt's Avatar
If that dosnt work,try the rev-limiter,This gives the same symptoms but also includes losing throttle responce and the inability to rev it.
Old Aug 12, 2008 | 12:46 AM
bobpo's Avatar
Hey Arcticcatdad,
Since I am void of any ideas at this point, I <u>will</u> try the coil. The thing that bothers me the most is that it only seems to do this maybe 1 out of 20 starts, but then as I think about it, it is usually in the evening (cooler, damper maybe).
I am going to assume that judging from your nickname you are older than lots of the riders these days. If that's the case, then I could be considered an Arcticcatgrandad having been born in the 30's. But I love the Arctic Cat ATVs and Snowmobiles.
Thanks again for the idea....
Old Aug 12, 2008 | 12:50 AM
bobpo's Avatar
Hey Coal Dirt,
You're right, the throttle will not respond at all. When I notice that it is starting to stall, I try to recover it with the trottle and this action does nothing but cause it to stall. Sounds like a great idea.
Thanks again.
Old Aug 12, 2008 | 11:17 AM
bobpo's Avatar
Cola Dirt, I have a backup question; where is the rev-limiter?
Valder
Nov 28, 2020 07:38 AM
fordfaithful21
Dec 7, 2015 05:52 PM
SDR-II
Sep 29, 2015 01:06 AM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
black798
Sep 9, 2015 07:42 AM
