starter on thundercat
Old Oct 19, 2008 | 10:22 PM
hay hauler's Avatar
Default starter on thundercat
im having problems with the starter on my 08 thunder cat (2nd one now ) when i ride it a few minutes it wont start back up tried a larger cold cranking amp battery it was no help herd there was a better starter for them but cant seem to find out anything and of course when i call a dealer or even articcat they tell me they havent had any problems i know of three of these having the same problems and since i put larger tires they voided my warranty anyone found a fix for this or am i the only one ! the bike is 6 mos old and has 64 miles onit im scared to ride it ti far afraid it wont start thanks for any info
Old Oct 19, 2008 | 11:03 PM
Mudbug5's Avatar
Welcome to the forum, Lots of good people and knowledge around here.
1. Kept original tires and rims so they wouldn't give me any crap about the warr. and the dealer I use said unless the breakdown is related to the bigger tires he could care less..
2. I have had to shim starters before and also make sure the starter disengages after it starts.
3. It was a different bike but on my 1400 V-twin it had a compression release on it and would not even turn over unless it was working correctly.
There are a lot of people on here that know alot more about that quad than me..
Good luck!
Old Oct 20, 2008 | 12:14 AM
Sindelir's Avatar
it really has nothing to do with the starter and everything to do with the decompression valve, pretty much all the 08s have this issue and even some 09s and its the decompression valve then when the motor locks up while its trying to crank it starts to kill the starter and thats why the starters are said to be junk, because they are but only because of a different problem, and yet cat has no real fix for it yet, let it idol for about 1 min before shutting it off and it should be fine my 09 even had the starting issue once but not very bad just let off the starter and hit the button again, oh and adjusting the valves dose not fix it, someone use to say its defective cams thats not true, My personal theory is to much advanced timing during start up when warm but the decompression valve has a lot to do with it to. Its not your battery like some say either, not starter, not battery, not the front cam, and its not the valves needing adjustment. Just narrowing it down for you. Visit arcticchat.com and there is a thread about it that is the forum I usually hang around, much more info there and a lot faster then here and a lot more answers there with good people.
Old Oct 22, 2008 | 10:00 PM
hay hauler's Avatar
thanks for the info not sure what to do except let it idle and hopefully that will help it ashame to have such a nice atv you cant do much with maybe articcat will figure something out and fix them if not i ghuess i bought my last one
Johnny Mac
Aug 15, 2019 03:13 PM
Lucas Bohanan
Sep 29, 2015 01:16 AM
wrencher82
Sep 28, 2015 10:02 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
