rear tires locked up
Old Sep 15, 2009 | 08:20 PM
blizzardblind's Avatar
Default Back on track
Well I ended up changing the rear wheel bearings, tore apart the diff, and serviced the oil for both the tranny and rear. All is well w/ the diff and the tranny(god i hope). The rear diff oil was a greyish black, and a lot more than was suppose to be in there I believe. It wouldn't even drain completely through the drain hole, turned out to be a real messy and stinky task! But no more awfull noises and my tires aren't locking up in neutral anymore so way worth it.
I did order new bearings and seals for the diff though, figured w/ the diff oil looking like it did it probably needs new seals. Thank u all for your suggestions.
Old Sep 16, 2009 | 12:32 AM
swampyjunior's Avatar
Check the little accordian like vent tube on the diff as well. I have torn mine before and not known about it until I got water in the oil as you described.
Also, it is normal to get some fine metal shavings in the oil magnet when you change the oil. I usually remove the drain then the filler plug and let it sit over night to drain.
SJ
Old Sep 16, 2009 | 09:07 AM
Ya the little accordion guy is good. Glad to hear that shavings r normal, was a little worried.
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
rcappie4
Jul 18, 2015 07:51 AM
rcappie4
Jul 10, 2015 04:54 PM
