2004 650 twin 4x4 problem
Old Jun 21, 2010 | 10:12 PM
stefanatv's Avatar
Default 2004 650 twin 4x4 problem
hey guys im new here and someone told me you guys were the pros that can help me,i have a 2004 artic cat 650 twin 4x4 and the 2wd,4wd switch is working and the relay is good but the 4wd wont engauge the drive shaft is spinning but im not sure if it is electronicaly control or enguaged inside the diff,there is some sort of module onthe side of the diff not sure if that could be it but it seems like it just went out over night,i checked the fluid and the relay and fuses and they all seem fine,guys i would appreciate any help.
Old Jun 22, 2010 | 05:53 AM
weez440's Avatar
when you hit the 4wd switch you should be able to hear the actuator engage it into 4wd. if you don't hear that actuator then your problem probably lies anywhere between the switch all the way to the actuator, could be the fuse could be the switch or it could be actuator. i would try looking at the fuse first off as alot of times it is the simplest of things. also your front driveshaft will always turn no matter if you are in 4wd or 2wd.
Old Jun 22, 2010 | 09:32 AM
stefanatv's Avatar
Default arctic cat
so the actuater is in the differintial right ,im sorry im kinda confused,what is the module on the side of the front diff,does it have anything to do with the 4wd or the actuater.i checked the fuses on the right side and they were all good and the relay for th 4wd to 2wd switch was good also,thank you very much for the help.
Old Jun 22, 2010 | 09:59 AM
cupsz71's Avatar
Cool
this is off an '08 TRV. It may not be exact, but essentially this IS the 4X4 ACTUATOR attached to the side of the front differential.
When you flip the switch/button you should hear a fairly loud "ZZZZZRRRP" sound. That's the actuator engaging the front differential to "hook-up" w/the front driveshaft. There's a little plastic gear in there to make this happen. If you hear the sound....but nothing happens.....your gear is stripped and the ENTIRE actuator will need replacing. If you DON'T hear that sound....you've blown a fuse......or you've got a bad connection.....or a broken wire somewheres.
Now on my '08 to engage the 4LOC....it's a completely seperate CABLE on the actuator that works w/the electric compontent/plastic gear part to LOCK-UP the front diff. Thus I have 2 switches on my handlebars. One for 2-4 whl drive....and one for 4LOC.
Hope this helps
my .02¢
Old Jun 22, 2010 | 05:19 PM
stefanatv's Avatar
Default atv
great advice and thanks for the pic,i got the actuater off and took it apart and the electric motor was covered in rust and was locked up i free'd the motor up but i think it is dead,guess ill have to buy a new actuater,it has power going to it though,does anyone know how much they run.thanks again for all the help you guys are great.
Old Jun 22, 2010 | 06:14 PM
cupsz71's Avatar
NP.
New they run about $200 from CountryCat or Babbits.
#0502-579
Ebay may be your new friend!
Old Jun 22, 2010 | 09:54 PM
stefanatv's Avatar
Default atv
thanks alot,iguess water or condinsation got in there but it doesnt work so ill b uy a new one for sure thanks buddy.
Old Jun 23, 2010 | 05:51 AM
weez440's Avatar
Arctic Cat ATV Front Gearcase 4 wire Actuator, 0502-579: eBay Motors (item 300439914800 end time Jul-22-10 08:07:37 PDT) here you go, this is actually the place i bought my new fourwheeler through this spring, they are awesome to deal with and their prices are hard to beat. glad you got it figured out.
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
Gtsordo
Jul 13, 2015 10:38 PM
Jul 7, 2015 11:00 PM
jettman
Jul 6, 2015 12:16 PM
