Starting issues
Old Jan 17, 2011 | 08:19 PM
pepper1126's Avatar
Default Starting issues
Just purchased a used 2008 AC 400 4x4, the previous owner just put in a new battery in the last few days and hadnt ridden it since installing the battery. It started up at the guys house and when i got home it was having trouble with the elec start so I had to use the pull start. The readout was reading VOLT. does that mean that the battery is dead or is the starter bad? once it was on, it ran great, its just start up that is kinda funny. thanks all and be ready for lots of questions from me
Old Jan 18, 2011 | 07:01 AM
rdeeno's Avatar
Check the battery voltage with a volt meter. If he stuck in the basic battery that you fill with acid and charge, he might not of charged it.
Old Jan 20, 2011 | 08:16 PM
07 400's Avatar
make sure you are getting 14.5 volts when engine is running.
Old Jan 20, 2011 | 08:18 PM
pepper1126's Avatar
What size battery should I buy? Any ideas. Probably going to walmart or autozone
Old Jan 20, 2011 | 08:31 PM
07 400's Avatar
get a bigger battery that fits in your compartment. arctic cat sells a bigger battery which it has more amps and lasts longer when useing a winch headlights and for starting the atv.measure compartment width length and height
chinkapin
Jul 14, 2016 06:58 AM
buckshit
Sep 24, 2015 08:49 PM
BEEFKING69
Jun 17, 2015 12:38 AM
Steven Bandemer
Jun 9, 2015 08:50 PM
1000gade
May 27, 2015 12:37 PM
