Head Light problem
Old Nov 1, 2001 | 01:17 AM
StitchZR2's Avatar
Get this, my hi beams work but my low beams don't. Any help on where I can start would be great.
Thanks for the help
Old Nov 1, 2001 | 04:31 AM
trailboss450's Avatar
25 Year Member
Three things it could be! Dimmer switch, broken or disconnected wire or both bulbs are burned out. If you have a test light, check at the connector near the headlight to see if there is power at both the high and the low beam circuit. If there is, then its just the bulbs. If not, go back to the dimmer switch and check for voltage there. Try it in both positions to make sure they both have power. If you do, then you will have to check the harness for breaks or loose connectors. If you dont have voltage coming out of the switch then the switch is probably bad.
I dont think they use a seperate fuse for each circuit but you should probably check fuse too just to be sure.
Trailboss450
Old Nov 1, 2001 | 10:35 AM
tbStone's Avatar
I had same problem though I haven't fixed it yet. Can you let me know what the problem was with yours?
thanks
Old Nov 5, 2001 | 12:27 AM
StitchZR2's Avatar
Well it was a blowen Fuse, Dont know how i blew it but with a new fuse it works great.
Thanks
[img]i/expressions/face-icon-small-happy.gif[/img]
Stillonit
Aug 5, 2015 07:46 PM
TLC
Jul 1, 2015 08:29 AM
Nelson
Jun 20, 2015 01:59 PM
Zorro
Oct 2, 2000 03:13 PM
