ATC 110 shift problem
Old Apr 5, 2004 | 11:09 PM
leafhopper's Avatar
Default ATC 110 shift problem
When a machine is not too old, it is less likely to have a transmission or shifting unit problems. What just happened to me (rather to my 2000 zx6r bike, - the transmission work is relevant, although it is not an ATV), is exactly what you described. So I could have ended up with a $1500 bill for replacing a gear or two at a dealership, while the reason is more rudimentary: a little bit deteriorated oil and stretched clutch cable. If you go through troubleshooting in most manuals, shifting problems will point first to clutch not disengaging properly, then you go to the clutch troubleshooting, and find that a lot depends on the oil viscosity and its level, and cable adjustment. I would say we'd rather start with the simplest, although our suspicions can lead us to the most expensive journeys. This is what I did: called dealers, contemplating paying the bill and thinking why my machine has not lasted me more than 4 years, and learning more, then playing with oil level and viscosity and clutch adjustment. It shifts like a Swiss watch would, just tested it an hour ago. Your forums helped, thanks.
Old Apr 10, 2004 | 09:28 AM
dzzy's Avatar
Ya, gotta turn the adjuster the right way, counterclockwise tho, not clockwise, until you feel the restistance then back clockwise a qaurter turn. Your clutch could be slipping, but the initial problem you posted sounds like a shift shaft spring, or arm that's broken, anyway some kind of a linkage problem. The linkage parts are under the RIGHT cover tho. You have to remove the clutch, and the big primary gear and you have access to the linkage. Lucky for you, it doesn't sound like a shift drum or fork problem.
Old Mar 3, 2021 | 12:11 AM
mulletman's Avatar
Default shifting problem
Hi, I am a first-time 3 wheeler owner and my 1984 act 110 transmission is not working right. when I say this every gear but second does not work in both high and low range. I've changed the oil and there were no metal shavings and when I shift it into 2 gear it acts like a neutral and I've looked everywhere on the internet for a way to fix it and I thought I would have some luck here. if anyone knows what's wrong I am open to any ideas that yall have.
Old Apr 20, 2023 | 05:07 PM
Amcaudill's Avatar
Default 1985 atc 110 shift problems
My 3 wheeler is piping out of gear in low and high low gear I have to sift 3 or 4 times to get it in gear any help
mmumm
ATC 3-Wheelers
Jan 10, 2016 06:15 PM
Madshad
ATC 3-Wheelers
Jun 28, 2015 02:43 PM
Rugburn
Oct 31, 2012 02:34 PM
thrashed200m
ATC 3-Wheelers
May 23, 2004 12:05 PM
thrashed200m
ATC 3-Wheelers
Apr 7, 2003 12:50 AM
