200x gears/tires
Old 04-05-2005, 10:12 AM
bigblock2stroke's Avatar
Default 200x gears/tires
I have to figure out what to put on my 200x for chain, sprockets, and tires.
Anybody know the stock dimensions for sprocket teet, number of chain links, and tire size?
I got the hole in the stator cover welded up last weekend and the engine fired right up after the carb rebuild. Just need chain and sprockets and my $100 (plus whatever for chain/sprockets) will be well spent.
Old 04-05-2005, 01:01 PM
ThrashAndCrash's Avatar
Front tire: 23.5 X 8-11 Rear tires: 22x 11-8 Chain is a 520 -88 link And the sprockets are 12 & 40
Old 04-05-2005, 07:32 PM
haywoodjalikme's Avatar
Hey bigblock
I bought my rear sprockets from SPROCKET SPECIALISTS and they are awesome sprockets. One option I have with my 83 200X is changing the sprocket sizes front and rear to 13/38 and 20" rear tires for the summertime when I just rip around in the dirt, but up here in northern Wisconsin I have to have aggressive winter tires so I switch back to the 22" rear tires and stock 12/40 gearing.
You can even use the same 88 link change with both gearing combos
The ratio with the 13/38 and 20" tires is a little lower so the top speed is higher and I have no problem pulling my 215lb butt around.
Just so extra info.
Jeff
Old 04-06-2005, 11:47 AM
Just the info I needed.
Thanks to the both of you.
Old 04-06-2005, 11:49 AM
P.S. I have a quote for $70 for stock gearing and o-ring chain. What did you pay from Sprocket Specialists if you don't mind saying.
I have also had good luck with Sidewinder Sprockets.
Thanks again.
Old 04-06-2005, 10:44 PM
$70 is pretty dam cheap!!! I can't recall what I paid for mine from sprocket specialists, I got them from DENNIS KIRK and they don't carry them anymore. The only other place I get parts from that carries them has a price of $55 just for the sprockets, chain and shipping not included.
Jeff
200x hill climber
Ask the Editor
06-10-2015 11:11 PM
88Warrior
ATC 3-Wheelers
08-07-2001 07:27 PM
hrc200x
ATC 3-Wheelers
02-07-2001 08:46 PM
bigmanm
06-28-2000 10:34 PM
200X
ATC 3-Wheelers
05-24-2000 10:47 PM
Quick Reply: 200x gears/tires
