185s Engine Rebuild needed or no??
Old Sep 13, 2005 | 11:54 PM
onyx2002's Avatar
Default 185s Engine Rebuild needed or no??
Hello All,
This is my first post here, and I'm happy to find an ATV site that has a section specifically for 3-wheelers.[img]i/expressions/face-icon-small-cool.gif[/img]
I was considering doing a rebuild on my unreliable 1983 185s, It smokes quite a bit, (black smoke)and is very hard to start, and sometimes just refuses to start at all.
I usually find the plug soaked upon removal, and/or badly carboned up.
I know I probably have fuel mixture problems as well, but have 2 different carb's, and both do basically the same thing.
It doesn't idle well , and will definitley stall out once it warms up, I've adjusted idle speed several times, and it still stalls out, even at higher settings. (air leak possibly?)
It appears that the spark is very, very weak , almost invisible,** but when I do get it to run its seems to perform pretty good, other than it smoking, and wanting to stall .
Another thing, when I pop a "wheelie" it will almost stall out too ..
Do you guys think i should bother with a rebuild? or is it probably just me not knowing enough about finetuning the carb?
I Don't think piston or cylinder, or anything has ever been rebuilt on this bike.
which shop manuals should i get that best describes troubleshooting these bikes.
THANKS IN ADVANCE
Old Sep 14, 2005 | 06:10 PM
cragster711's Avatar
hello, welcome to the boards!
i really dont know too much about engine's
but i will say that
EDIT [img]i/expressions/face-icon-small-happy.gif[/img]
mods can remove this link if its not allouwd!
Old Sep 14, 2005 | 07:01 PM
soulreaper2222's Avatar
well my 185s did the same thing u'll need to get new rings for the smoking cuz mine had a big gap gone it them and maybe will have to bore it over atleast .20 r higher if u want alot of power mine if .80 over and it is bad awsome.i dont know to much bout carbs yet im just learning how to work them really.
Old Sep 14, 2005 | 07:57 PM
onyx2002's Avatar
Alright.. thanks guys, I know someone else here will be able to help.
I've read alot of posts, and the guys here seem to really know their $tuff.
Old Sep 14, 2005 | 10:57 PM
xljimmy's Avatar
Black smoke is ussually a fuel problem. Blue is oil. The fuel smoke is almost eye watering. Oil smoke is mainly just stinky. It sound like it is running to rich. Play around with the adjustment screw and see what happens. Just turn it in and count the turns before you start playing around with it so you know where it was. When you do the wheelie your float doesnt working right because of the angle but it should just dump fuel out the overflow. I would check the overflow tube for a blockage. Maybe the float isnt adjusted right. It would normally leak gas though so if it isnt leaking and the overflow isnt block it is probably alright. I would mess with all that before a rebuild. My atc90 runs pretty well and it only has 95lb of compression instead of the minimum it s 150lb. It does smoke worse then any two stroke though and always starts on first pull. It is hard to say and would hate to point you in the wrong direction. Just giving you ideas.
Old Sep 16, 2005 | 01:19 PM
ThrashAndCrash's Avatar
onyx2002...
Can you do a compression test on this engine? If so... get me the #'s they will be very helpfull.
Is there oil in the muffler?
How often do you need to add oil to the engine? What oil are you using?
Could you get me a picture of the fouled spark plug?
My first impression of what you said is that it needs a upper-end; but I will help you narrow it down a bit.
Old Sep 16, 2005 | 11:10 PM
JkAss's Avatar
Whats up Trash? You're a Mod, but not a supporting member. Just messing with you. I agree with Trash sounds like the top end needs work. My sons TRX 70 did the same thing. Re built the top end the thing runs like a champ.
Old Sep 19, 2005 | 12:22 PM
It JUST expired!!!!!!!! Waiting on "the boss" to give me the $15 to do it again!! [img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img]
Old Dec 6, 2005 | 08:36 PM
lawnboymelvin's Avatar
hi i think you should rebuild it because it smokes plus if is hard to start it might need gaskets
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
brinkkl2000
Jun 11, 2015 12:46 PM
Dieseltrash
Jun 6, 2015 09:53 PM
Dieseltrash
Jun 1, 2015 06:53 AM
