how much more speed..
Old Oct 2, 2005 | 07:03 PM
soulreaper2222's Avatar
Default how much more speed..
i have a honda 185s wut im about to fix up really nice with clutch kit,new rings,chain,both sprockets front sprocket has 13 teeth and rear has 38 like a 200x,and a dg rcm pipe.How much more hp and speed will i get out of it when it does atleast 45 or 50.
Old Oct 2, 2005 | 07:35 PM
ThrashAndCrash's Avatar
the 200x had 12/40 gears on it..........but the 13/38 will be pretty darn close.......if the olny mod you have is the exhaust and the rest is just fresh stock stuff, +2 HP if jetted correct would be a close guess. not sure on your speed, what was your old gearing with the 45-50mph?
My 200x did 66mph with stock gearing, hollow exhaust, jetted, ported and polished head, .030 overbore, and the old balloon tires
Old Oct 2, 2005 | 07:41 PM
well i got a k&n i aint put on yet, its bored to a 200 with a wiseco piston and rings,and has a 200x carb on it.
Old Oct 2, 2005 | 07:42 PM
If you can get ahold of a good used 200x cam, it would make a big difference
Old Oct 2, 2005 | 07:44 PM
do u know where i could find one and if i do would i have to exchange timing chains and all?
Old Oct 2, 2005 | 07:49 PM
e-bay is the best place, and it is a dirrect swap....no other parts needed. then jet your carb up a touch
Old Oct 2, 2005 | 08:23 PM
ok thanks for the help well after that do u think i could hang with a stock 200x r out run it?
Old Oct 2, 2005 | 08:27 PM
?????????? It would be close............ [img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img]...............could be down to the driver at that point!!!!
Old Oct 2, 2005 | 08:29 PM
ahh ok i got couple of last questions is a 185 and 200x motor almost the same r wut?are they cluth driven?also would the rear sprocket off a 200x fit my 185s?
Old Oct 2, 2005 | 08:50 PM
yes the 185 and 200x ENGINE (its an engine not a motor [img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img]) are very close.......the bores are different, cams, and carb.....other that that the same! What year is your 185s?
