200x Clutch
hey i picked up a 198? somethin honda 200x atc today. it runs and drive great. it has to problem though. 1: the kick start slips and doesn't turn the engine sometimes and 2: the clutch sicks and stays engaged after i fully release it. I have loosened up the line so there is way more slack than need but it is still sticking. What do i need to do. THANKS
1: Sounds like the kick starter shaft is screwed up inside. Which woild require a bottom end teardown, but I could be wrong.
2: Sounds like you need a new clutch, most likely the whole kit. Plates, discs and springs. You can find kits for $60-$80. Hopefully your clutch basket is ok. Those can be expensive.
if you would like to say it that way then yes that is what i mean. when i fully release the clutch lever (with plently of slack in line) the clutch stays enaged (or the gears don't) engage. It seems as if i am still holding the clutch lever in even when it if fully released.
cdstang
Aug 31, 2015 07:52 AM
