first threewheeler!!! YAMAHA YTM200
I would check all the bearings. See if the hubs are welded on. Check and see if it smokes. See if it has been bored out. see if the casing is cracked. see if it shifts through all the gears smoothly. and just all the normal checks you would do when buying an atv good luck and hope it all works out.
09-23-2015 06:23 AM
