84 200x problems
Old Jul 30, 2006 | 04:06 PM
69chevyman's Avatar
Default 84 200x problems
im workin on a 84 200x honda 3 wheeler and am having trouble with it running good it sounds like its getting to much gas but i can tighten the screw on the bottom of the carb and it is still getting to much gas.Do you think a carb kit will help my problem also what is the differnce in an 84 and 86 carb kit
Old Jul 30, 2006 | 06:05 PM
HondaAtcRoxz's Avatar
WELCOME TO THE FORUMS!!!
Yes a carb kit will help your problem out if it is in fact getting too much gas. Have you checked your plug to see if it is wet after running or a bunch of carbon built up on it??? There is no difference in the carb rebuild kits they are the same carbs I think. But I would be on the safe side and buy the 83-85 200x. There are a few on ebay right now.
Good luck
HondaAtcRoxz
Old Jul 30, 2006 | 08:57 PM
HondaMechanic's Avatar
none
Old Jul 31, 2006 | 03:16 AM
KNOWSALOT's Avatar
The Facility
Don't even consider a carb issue until you have checked that the valves are in spec first.
You said it "sounds" like its getting too much gas, so start with the basics of tuning before assuming parts need replaced.
However, you may need a valve adjustment AND a carb rebuild. : )
Also,welcome to the forums
Old Aug 22, 2006 | 10:58 PM
crazyrider1's Avatar
yea if it is the carb-
check the needle and seat that the floats sit on to see if there worn out ,if it isnt shutting off the fuel it will just keep flooding ,and turn the plug black,no matter of the valves
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
