200s gearing
200s gearing
you could try a front sprocket that is one tooth more, but this does not necessarilly mean the bike will be faster. If the motor doesn't have the beans, the bike could end up being slower because the gearing would be too high.
Another more expensive way would be to invest in a few aftermarket parts for more power. These might capitalize on the stock gearing, allowing the bike to produce enough power to reach the top speed the gearing permits.
Combining both of these will produce the best results, but the bike will most likely have a harder time going at lower speeds because the gears would be too tall.
My advice... some performance parts.
200s gearing
Im from southern wisconsin so that wouldnt be too far. But this is up to my friend, he wants a faster machine that can do jumps, so this sounds like the ticket. how good of shape is the r. the 200s problems are cosmetic the seat ripped and in bad shape the back plastic is not in good shape and it needs a new front brake handle, other than that its fine. with some minor rust and a slight carbuerator trouble when cold.of course if he was going to trade you he would throw in a good sum of money. but the problem is that his money is in a CD and does not get out till Febuary. BTW you do know this machine is rigid[img]i/expressions/face-icon-small-happy.gif[/img]
