Help with 200m
Old 04-11-2008, 09:10 PM
MyHatetredBleeds's Avatar
Default Help with 200m
I started getting back into fixing up my 84 200m. Theres a few things I need help with.
the front shocks need rebuilt. I've never done that before and have no clue how to rebuild them. Is there a site with a break down for them?
I found a better looking front hub and went to put it on and ran into a few problems. the bolt pattern was wider then the hub that was on it. I was thinking that the guy i got it from put a 185 front hub on. Could that be possible?
Its not running right for some reason when you hit about half throttle it starts cutting out kind of like it has a rev. limiter on it. I know it doesn't have one, I tried readjusting the carb but it didn't change a thing. Would that mean theres a jet maybe half plugged? Any info would help me out. Thanks.
Old 04-11-2008, 09:48 PM
sdm111's Avatar
2 strokes or 4
For the forks you can go to Dan's motorcycle repair and engine repair guide online can't remember the address just search it. As for as the throttle sounds like you need a rebuild kit. And don't know about the hub.
Old 04-12-2008, 07:51 AM
Ok thanks for your help Ill see if i can find the site. I had it bored out awhile ago but don't remember how far. Would I need a different rebuild kit or would the stock one still work
Old 04-12-2008, 09:49 AM
sdm111's Avatar
2 strokes or 4
I'm sure you do but I don't know jetting Here is that website I was talking about http://www.dansmc.com/mc_repaircourse.htm
winterwolf
ATC 3-Wheelers
06-03-2015 07:34 PM
Bob427
8
01-23-2013 07:35 PM
jonnyneutron
ATC 3-Wheelers
05-27-2006 10:00 AM
MyHatetredBleeds
ATC 3-Wheelers
06-01-2005 12:40 PM
WeaponM200
ATC 3-Wheelers
10
08-02-2004 01:15 PM
Quick Reply: Help with 200m
