200x?
Old Jan 17, 2003 | 11:28 PM
mad200xer's Avatar
Default 200x?
If I were you hoss,
I would not believe anything about the reliability problemns of the early 200x's, that only happens if you run the dog **** out of them and don't take care and do regular maintenance... I have never had a problem with mine
Old Jan 20, 2003 | 12:07 AM
hrc200x's Avatar
Default 200x?
A common problem for the early 200x's is the kick start gears inside the case go bad. I've also heard of the later 200x's actually breaking off the kick start shaft. I think they are very relyable machines. I'd probably leave it stock with the exception of a pipe and filter.
Old Jan 21, 2003 | 01:36 AM
4wheelr220's Avatar
Default 200x?
How hard is it to replace the kickstart gears when they go bad??? Mine bit the dust right after I bought it and I only got to ride it 4 times. I would like to fix it up a little bit and use it as a play bike. Thanks for any help.
Old Jan 21, 2003 | 05:21 PM
mad200xer's Avatar
Default 200x?
It is acctualy easier then most would think as long as you have 2 things. A book, or shop manual. People really underestimate these books but they will help you through alot, regardless what the problem, most of them give a little insight into everyhing. The ohter thing you will need is basic motor common knowledge. other then that you would be good to go, if you need anymore help let us know, I am sure that others on the board are willing to help you out as well as I... Take it easy
Josh
Old Jan 26, 2003 | 05:17 AM
  #15
RoostKing's Avatar
Default 200x?
Theres an 87 200 X for sale here in Phoenix.. Awesome shape !!
RoostKing...
200x hill climber
Ask the Editor
Jun 10, 2015 11:11 PM
88Warrior
ATC 3-Wheelers
Aug 7, 2001 07:27 PM
hrc200x
ATC 3-Wheelers
Feb 7, 2001 08:46 PM
bigmanm
Jun 28, 2000 10:34 PM
200X
ATC 3-Wheelers
May 24, 2000 10:47 PM
