ATV Expeditions Are you on a major excursion traveling the World or a Continent. Post your adventures and log your travels here.
AWD wire connector location
Old Feb 16, 2022 | 04:38 PM
TooLate's Avatar
Exclamation AWD wire connector location
Did some brush work with the Polaris 500 HO pulling a field and brush mower. At some juncture, the brush traveling under the ATV pulled the wire serving the AWD module from its connector...no indicator on the speedo and no AWD. All is well, wire and plug wasn't damaged BUT...where in the world is the connector located for this wire and plug?? Judging from its length and dust-freeness, it's up near the headlight/speedo area as it was draped over the front axle where I found it. UNIT: 2004 Polaris ATP 500 HO (same layout as a Sportsman 500 HO perhaps??) So, where is the bugger? Of course, I removed the snow blade to mow and for the moment, there's no AWD...8-10 inches predicted tonight!!
stendori
Aug 30, 2015 11:27 AM
chikester
Nov 3, 2008 06:10 PM
edoyle
Feb 13, 2005 08:31 AM
Mj4all2use
Sep 13, 2004 11:13 PM
Mj4all2use
Jan 15, 2004 11:57 AM
