building a jump. do i need i down slope?
Blaster2fast didn't take care of his quad that is why it was a pos. and he was always to much of a dumb *** to put it back together right so things just kept breaking. my blaster was awesome and ran great. neva had a problem. and he rebuilt it wrong like 4 times. i ride with him all the time and ride just as hard if not harder.
.i did everything cleaned filter lubed chain changed oil.... that thing was just plane ol a pos rebuilt it 4 times.. AKA$$ just rides like a lil girl
if you have ever ridden a blaster hard... you would know its a pos
Roosthrower, try stiffening up your front suspension if you can, and keep your weight as far back as possible. I had a problem with my Z250 nosediving, but now its fine after I did that.
The approach to your jump needs to be at least as long as your quad. If not, your front springs are recoiling while your rear is compressing. Then when your rear end recoils it will pitch up and try and throw you over the bars. It's also very hard on the wrists to hit a short faced jump.
#15
I build about a 5 foot tall ramp and I needed a landing ramp but wasnt sure where to put it. Another problem is after hitting it a few times I always want to jump bigger and farther, so this is what I did. I got a big piece of plywood(I use 4'x8'), and built the landing on top of it. I cut a hole in the front of the board and when I wanted it longer all I did was hook a chain to it and to my Raptor and pulled it however far I wanted it.
#16
Our jumps you go about 4 feet high and 25 feet far. Never had a problem bottoming out. We have another jump thats right after a turn so you dont have much speed. We go about 5 high and land pretty hard. Its not that bad tho.
#17
what you do is build the jump and if u dont liek landin hard. mark were ur rear tires are hittin a build a small landin about 3 ft behind that and about 2-3ft off the ground just depends on how high u are.. i got some pix of my new 30ft doulbe but i have to get them up yet
Stirling
Aug 9, 2015 01:49 PM
