lower quad = less traction?
I'd guess the road conditions have more to do with it than anything. I wonder what it would do on asphalt.
The swingarm should be level or above. ie: the swingarm pivot should be higher than the axel. If the pivot is lower it could be causing the lack of traction.
the black top is only 6 months old and is cleen. my swing arm is streight lined up with the frame. like from that i can now beet raptors in drags cuz i can dump the clutch at 8000 rpm and take off no wheelies
look at my pics to seee how low it is and the angle of the swinger
LOL, I think things got confused. [img]i/expressions/face-icon-small-smile.gif[/img]
After your 2nd post, I figure you like the way it is, and prolly should! Seems you found the set-up to accomplish a great holeshot w/o raising the front tires. [img]i/expressions/face-icon-small-cool.gif[/img]
The topic question lead us to believe you were unhappy with the way it is.
OK, to hopefully answer the topic question:: we raise/lower the quad to get more/less traction and lower the center of gravity (or change it). It is known that you get less traction once the swingarm pivot goes below the axel. Altho some may like that way.
Real estate has location.
Quads have set-up. Whether it's for MX,TT,XC,etc. Congrats [img]i/expressions/face-icon-small-smile.gif[/img]
well i like puling wheelies and noiw i cant. but the hole shot thing is good except i have less than a inch of shock travle in the rear.
Frisky2050
04-09-2020 11:19 AM
