stock comp ratio?
Old May 18, 2003 | 11:34 PM
suprdavtn's Avatar
Default stock comp ratio?
looking for advice on uping the comp. to get more bottom end andhave no exp.in this help please.
Old May 18, 2003 | 11:38 PM
SANDMAN430's Avatar
what kind of riding are you doing a sprocket change in the back might get you what you want without the engine work.
Old May 18, 2003 | 11:46 PM
chop's Avatar
or you could drop one tooth in the front,i did and was very happy with the torqe gain.youll loose top end but gain alot of bottom end.
Old May 18, 2003 | 11:58 PM
suprdavtn's Avatar
been there and done that worked well need more.
Old May 19, 2003 | 12:02 AM
SANDMAN430's Avatar
the problem is doing a piston your in there and it's a great time to do cams and port work.
Old May 19, 2003 | 11:23 PM
suprdavtn's Avatar
tell me more sand man
Old May 20, 2003 | 12:19 AM
DuneMe's Avatar
Sandman is right, first. . . what kind of riding do you do?
Now if you like to climb and want to say, Oh my freekin' god . . . the following will help:
High compression piston 11:1 for pump gas 12:1 for race gas or 13:1+ for alky
Cams (you will lose some low end grunt so if the answer to the question above is trails - you may want to pass on the cams.)
Port work (anything from mild port work to a full race head (Pami, Ron Wood, TVI, etc.)
If you do the cams you will probably need to do heavy duty valve springs and if you do those you will want to do shim under bucket design.
Now that you have all this power you need heavy duty clutch springs.
And you will probably want the TM45 carb and a real good high flow pipe.
Old May 20, 2003 | 01:36 AM
CrazyWhiteDude's Avatar
ain't that a bitch
Pehter
Oct 3, 2024 11:00 PM
dannytas
Sep 26, 2017 06:31 PM
Honski250r
Sep 26, 2015 09:40 PM
rockinkgin
Sep 25, 2015 01:52 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
