Dual Lectron help, please.
Old Jun 5, 2003 | 09:42 PM
sixsixT's Avatar
Default Dual Lectron help, please.
Ward even with the 90 Degree they won't fit from what I've seen. They are nice carbs. tho I had one on my YZ 250.
Old Jun 6, 2003 | 01:03 AM
Hurycne's Avatar
Please dont give bad info. I run dual 40mm lectrons on alcohol. You need the cable from fast by gast which I have an extra of. Make sure you get adjustable power jets and it will be great.
Old Jun 6, 2003 | 02:25 AM
sixsixT's Avatar
Originally posted by: Hurycne
Please dont give bad info. .
I don't know if that was directed at me but I don't think it's a bolt in for a RAPTOR.
Old Jun 6, 2003 | 06:22 AM
Ward660R's Avatar
I does NOT have to be a bolt on. I don't mind cutting, drilling, spacing, or whatever.
Hurycne, do you have any clue what the measurment is from the center of the bore to the highest point where the cable will still function? Maybe I'll just check them out on the 28th.
I don't want to buy some and then not be able to use the dang things.
Old Jun 6, 2003 | 11:42 AM
  #15
sixsixT's Avatar
Here's some more info. I hope it's not bad. [img]i/expressions/face-icon-small-wink.gif[/img]
Thu February 13, 2003 7:59 AM
I looked at the lectrons even had some in my hands from another bike. They are too tall to fit under the tank. The cables pull from the top like a dirt bike and need 3.5" of clearance from the top of the ventura even with the 90 degree adaptor. Tried to modify the tank but the pedcock is to close to the carb's.
Old Jun 6, 2003 | 10:25 PM
  #16
Hurycne's Avatar
660 it was not at you but someone was talking him out of it. The only thing that sucks is that you will have to go with a twist or modify your thumb throttle casing
Old Jun 7, 2003 | 06:38 AM
  #17
Ward660R's Avatar
Modification is what it all about.[img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img] I know I don't want a twistie.
I don't "think" 3.5 should be a problem, not a big one anyway. Time to go check!!!
sixsixT, who is that a quote from?
Old Jun 7, 2003 | 10:09 AM
  #18
sixsixT's Avatar
Trirap I think. Found it doing a search on the yamaha page "lectron"
It sounds like he measured from the top of the bore not the center, so you'd need to add at least 3/4" to measure from the center.
Sep 30, 2015 01:37 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Pahuntman
Sep 5, 2015 11:07 AM
Kodiak-vic
Jul 29, 2015 03:06 AM
