Feeling Great about my DS !!!
Old Jun 25, 2003 | 06:29 PM
  #21
Bellracing2's Avatar
Default Feeling Great about my DS !!!
I did the spring trick and it works great all the time.
Old Jun 25, 2003 | 08:44 PM
  #22
bombrider's Avatar
Ya mine dos to
Old Jun 25, 2003 | 10:19 PM
  #23
PUSHINTHELIMIT's Avatar
Andrew,
That's pretty much all I do it trail ride. IT DON'T AFFECT ANYTHING EXCEPT REV QUICKER. But just don't cut more than 6. I find 6 is the best...... Or as I said before.. the magic #... [img]i/expressions/face-icon-small-wink.gif[/img]
If you cut more than that it will run lean on bottom end.
Old Jun 26, 2003 | 09:56 AM
  #24
DStroyer's Avatar
Has anyone trid this on the 45mm carb? Or is it just not needed?
Dstroyer
Old Jun 26, 2003 | 12:02 PM
  #25
TyreSpinner's Avatar
The 45 carb does not need a vacuum to open the slide. The slide is opened manually by the throttle. There is no such spring on the 45.
The only springs are the throttle return and the Acc. Pump spring.
Jeff
Old Jul 2, 2003 | 12:08 AM
  #26
racerx5x5's Avatar
Is it normal for it bog a little when you dump the cluch in second gear. It come out of it in a couple of seconds. Should I go down on the clip?
Old Jul 2, 2003 | 12:19 AM
  #27
racerx5x5's Avatar
How can I help the bottom end? I thought I might take off a couple of disks. Would that help?
Old Jul 2, 2003 | 02:45 AM
  #28
BlackHawk's Avatar
I've heard that for more bottom end power, you want more back pressure in the exhaust - so yes, more disks should do that for you, there is only one sure fire way to know though.
Reactant
Mar 30, 2022 02:08 AM
greg74
Sep 10, 2019 03:03 PM
papahouse
Jul 28, 2015 12:42 PM
bpegram84
Jul 22, 2015 08:12 AM
ghost civic
Jul 19, 2015 10:13 AM
