valvoline 15w 40 for ds650 ???
Old Jul 7, 2003 | 09:40 PM
pads's Avatar
Default valvoline 15w 40 for ds650 ???
I use the stock oil also. I found it for $7 a quart though. I only ride enough to change it twice a year anyway.
Old Jul 7, 2003 | 09:57 PM
Slowride's Avatar
BajaMark, must be nice to be crazy and rich. [img]i/expressions/face-icon-small-smile.gif[/img] I got the crazy side covered.
The 5 year warranty doesn't care what oil I run. However, if there is an oil based failure, you know they'll claim I ran it low.
90+ degrees in the sand? I would run 20-50w. Thinner in the winter.
jbt
Old Jul 8, 2003 | 02:20 AM
Gaskett's Avatar
PUSHINTHELIMIT
The premium blue is not just for diesels, it's just certified for diesel use. Which means it carries all the same certifications for gas, plus extra's for diesel operation.
I drive a diesel pickup, so all I use is diesel certified oil in all my engines (lawnmower, 4Runner, Ford truck, and the DS). It has better viscosity retention, better anti-foam agents, and has better soot encapsulation abilities than standard gas certifications.
Especially in high revving engines, the anti-foaming ability is the best benefit.
Just my .02 cents,
Glenn
Old Jul 8, 2003 | 01:49 PM
olefin's Avatar
Originally posted by: MCBRIDESTER
i the dealer said .....but he also said that my warranty might not cover the engine in the case of problems not even related to oil problems......what do u do?
Dealers come and go... Use the oil that is specified in your owners manual.
There will be one or more API specs listed. Read the label on the can of oil, don't use it if doesn't meet one of the API specs listed in your manual.
I use Valvoline ATV oil, cost about a buck more than regular car oil. May be worth it for it is special made for ATV's.
It list this:
Meets or exceeds manufacturer's warranty requirements. Will not void warranties.
Meets or exceeds API SF/SG/SJ
Meets JASO MA specifications
MRDS650
Feb 22, 2026 11:26 AM
lightninboy
May 16, 2021 09:52 PM
ScoobyDFW
Jun 13, 2000 11:33 AM
KawasakiKid
May 11, 2000 03:42 AM
ScoobyDFW
Apr 10, 2000 06:52 PM
