installed mbrp...but headers started melting the hose!!!!
Old Aug 24, 2003 | 09:33 PM
R00ST's Avatar
Default installed mbrp...but headers started melting the hose!!!!
i finished installing the MBRP full exhaust (headers and back)
and i for some reason never paid attention to the fact that the either oil or coolant line running to the engine case hits the exhaust header....
i had only run it for around 3 mins, got off and saw a bit of smoke (it was the rubber melting)
it only grazed the outside, and didnt penetrate the hose...but now i have the problem of relocating it... (i COULD shift it to one spot where it wouldnt touch the headers, but it makes it almost kink at the engine)
what exactly runs in this hose? (can i undo it and run it on the OUTSIDE of the exhaust heat deflector? (on the right side)???
hmm what to do
any hep is appreciated...!
Old Aug 24, 2003 | 09:39 PM
BillDS650's Avatar
It is the crank case vent hose I re-routed mine up the post for the radiator
Old Aug 24, 2003 | 10:11 PM
DSJOBBER's Avatar
Carefull those headpipes will get red hot... Check them out when you ride at night. The head pipes started to destroy me carbon fiber exhaust guard. Im working with the manufacture to find a solution to the problem. Keep any and all hose wires and skin away from the head pipes. Hot is a understatement...
Old Aug 24, 2003 | 10:49 PM
TyreSpinner's Avatar
Yes...I ran my Woods headers without the heat shield...
You should see my inner knee now... Looks like a scene from the Exorcist or something.... Don't try to reverse the quad without getting off the bike if you don't have a heat shield... I was pushing backwards with my feet on the ground and somehow got in contact with the header... I now know how to dance and jiggle [img]i/expressions/face-icon-small-smile.gif[/img]
Jeff
Old Aug 25, 2003 | 12:30 AM
R00ST's Avatar
ok, so if its just a breather hose, there is no fluid traveling through it (no pressure?)
so where does the top of the hose go to? (is that what i would need to relocate?)
is the top of the hose just attatched somewhere up by the airbox?
but ya i have 4 burns on my arms/hands already from those dang headers...(have some nasty scar tissue and blisters)
Old Aug 25, 2003 | 12:51 AM
BabyMoose's Avatar
If it is the hose I think your talking about, I do believe that it runs into the hose that goes into the left side of the air box.
Old Aug 25, 2003 | 10:02 PM
R00ST's Avatar
so can i just pull the hose out of where it goes under the seat and move it over by the radiator?
Old Aug 25, 2003 | 10:36 PM
BillDS650's Avatar
That is what I did check out this photo
Old Aug 26, 2003 | 10:10 AM
SANDMAN430's Avatar
you will need a small filter for the end when you re locate it so sand and dirt don't get in there and go down into the engine, most auto parts stores have small filters you will see them when you look for them.
buckshit
Sep 24, 2015 08:49 PM
Stillonit
Aug 5, 2015 07:46 PM
1000gade
May 27, 2015 12:37 PM
kencbs
May 23, 2015 05:29 PM
