How high will your engine REV with a stock motor on 5th?
Old Aug 26, 2003 | 01:19 PM
uthatch's Avatar
Default How high will your engine REV with a stock motor on 5th?
My '04 Baja X revs right to the limiter in 5th. The tach vibrates around some but it looks like 7900-8000. I know for sure if it had one tooth small rear sprocket, I'd get at least a few more mph. It hits the limiter going up hill even. It sucks because it's only as fast top speed as my best friend's Raptor. In fact, if I leave off a little bit and just barley kiss the limiter, it seems just a little faster.
I'm getting new tires today, so they might be a touch taller and that too might make the difference.
Oh yeah, I weigh 140 lbs. completely ready to ride. Don't be knockin' the lightweights out there, I'll whip anyone in my area!!
Old Aug 26, 2003 | 01:44 PM
bigben's Avatar
On flat loose gravel, mine will hit the stock limiter in fifth. Stock gears, stock tires, with me at about 280. Stock front a-arms too, that "twitchy steering" really shines at those speeds and on that surface. I like to hold it pinned, that's why I'm hesitant to get a CDI without a rev limiter.
Old Aug 26, 2003 | 05:05 PM
DCryder's Avatar
Just by my experience from all the different gearing/tires setups i have tried i doubt you would ever rev past 8500 rpm. Mine with 14/40/22" Razrs (which are about 2" taller than my 22" XCTs) it would max out at 8000, with 15/40 about 7500. Right now with my 22" XCTs/15/42 it will crank 8200. I weigh 190 lbs (dry weight).
EZRyde
EZ Ryde Exhaust
Jul 30, 2015 12:46 PM
NONEtooSMART
Jun 17, 2015 08:48 AM
hugemoth
Jun 4, 2015 02:56 AM
kevbowe
Jun 1, 2015 01:17 AM
JackOReilly
Dec 7, 1999 09:12 AM
