Figured the problem out.
Old Sep 4, 2003 | 09:30 AM
mystereid's Avatar
It's official, I've been duning for over 30 years.
Default Figured the problem out.
Hightower, I thought a rev limiter for Nos was a big no-no? If you cut the spark you pack in fuel and Nos and when it comes back on Kapowie!!!
Old Sep 4, 2003 | 10:42 AM
SANDMAN430's Avatar
well i saw what cdi jeff was running and he has to be the biggest nos junkie out there, it was the woods . proper clearance and things should be ok i've over reved mine plenty.
Old Sep 4, 2003 | 04:48 PM
mystereid's Avatar
Um, does the Woods CDI have a rev limiter? with all the different CDIs out there I can't remember.
Old Sep 4, 2003 | 04:50 PM
DCryder's Avatar
Nope.
Old Sep 4, 2003 | 05:13 PM
  #15
buttfungus's Avatar
Originally posted by: Hightower
I have the shim under conversion and dual rates from web, I like to rev and my motor likes it too, but like Mark said the shim under only comes into play after you bring a spring or cram a valve.
I plan on nos this winter, and I'll dam sure be sporting a rev limiter before the bottle goes live.
with a stock motor the hp drops off just after 6K on the tach, never saw much use for a rev beyond 8K, but I've yet to see a dyno chart of a motor setup like mine to know where the numbers fall. I'll be going on a dyno soon to find out, and prolly get the vortex programmable cdi later on this winter (if i go thru with the n2o plan).
Chris, some stock motors with stock cdi's are still making power over 6k with the right carb.
Dyno's of stock motor/stock cdi with Lectron 46HV....
toonces
Oct 16, 2019 12:11 PM
JBibb
Jul 4, 2015 10:16 AM
Shifts
Jul 3, 2015 07:59 AM
DOAinNY
Jun 11, 2015 10:34 PM
