Aftermarket Grab Bars
Old 11-06-2003 | 03:11 PM
TexasPsycho's Avatar
Default Aftermarket Grab Bars
if you have time to wait go to eastwood catalog and they have everything you need to polish metal and seal it so it doesn't oxydize. i think their web site is www.eastwood.com i just start out with 180grit to get it all smooth then go up to 400grit then 600grit. if you can find ribbon sand paper it works best because you can wrap it around the bar and work it back and forth getting both sides. when you finish the sanding you can just use some mothers polish to get it shinny. the bar polish is a hard bar of polish that you apply to your buffing wheel. if you use the mothers don't put to much on or the buffing wheel will sling it all over you. you can buy some buffing wheels that go on drills that will cover a larger area. you can do the same thing on your rear axel to make it look good.
wendal
09-07-2019 06:46 AM
EIF
04-20-2017 07:15 PM
cboler9
09-24-2015 08:35 PM
Todd C Wadas
2) Chassis problems..
09-23-2015 11:31 PM
95scramblerruben1033
09-23-2015 06:29 PM
Quick Reply: Aftermarket Grab Bars
