BEST FRONT SPROCKET FOR 22" RAZOR REARS
Old 01-29-2004 | 09:31 AM
GEARSMOKER's Avatar
Default BEST FRONT SPROCKET FOR 22" RAZOR REARS
i run cross country races and installed 22' razors on the back. however now, i can't start off in second anymore. how many teeth is the front sprocket stock, and what size should i get to get the low end power back? since i only race cross country, top speed is not important, just low to mid power.
Old 01-29-2004 | 09:35 AM
DCryder's Avatar
Stock is 16/40.
15/42 or 15/43 is very good with 22" tires, pretty much puts you back to stock gearing.
A 14 tooth on the countershaft will let the chain rub the swingarm pivot nut.
Old 04-10-2004 | 07:03 PM
Dingo2's Avatar
Anyone have any idea the size of that engine mount nut..near the back of the engine. I'm having a hard time removing it and need a socket (1/2") to fit my impact wrench...Thanks
Old 04-10-2004 | 07:38 PM
JMAC650's Avatar
I put on a 15t with my 22" holeshots and WOW! night and day difference.
Old 04-10-2004 | 08:30 PM
MudStud's Avatar
14t!!
I ran 16/15/14.
15/40/22 is TALLER then stock gearing... 14/40/22 is JUST a bit shorter then stock giving you a power advantage and only a slight top end.
TheHood
07-26-2015 09:51 AM
rcappie4
07-18-2015 07:51 AM
Peter_
07-18-2015 07:06 AM
tporath
07-11-2015 12:31 PM
cSchwartz
07-09-2015 02:40 PM
Quick Reply: BEST FRONT SPROCKET FOR 22" RAZOR REARS
