one more carb question
Hey Eric, while you're looking at this, I thought I'd chime in. I've talked to Randy about this, and found that you already looked at it...... Two holes drilled in the top of the slide to remove some of the pressure. We used to do that on dominators to help the idle. What about two more holes and then adjusting the mix screw out a tad more???? Any chance that it might help? Knowing you, you've probably tried, however just in case........ figured I'd bend your ear a bit.
I like this carb the only thing is this vacuum at idle problem i got my bike in a little bit of a bind gave it a little trottle vacuum broke lose flipped the bike over on myself. Still black and blue from that one. I polished the slide that helped a little. It runs so well i hate to mess with the needle but i might need to try that we need to work this out i am going to put in a 730 kit we trail ride at the dunes so a smooth trottle action is a plus.
this is the only issue with this carb MRHP sent it to me i took it out of the box put it on and went riding now that is what i am talking about more riding less jetting B/SH#T
