Not sure I like this...
I just put some RWR 60%( I ordered the 40% springs but they substituted the 60s because they were out of stock ) stiffer springs in my DS and they seem really stiff, the lever pull is substantially harder than stock. The girlfriend is not even sure she'll be able to ride it...
He probably means the shaft that you had to adjust. Have you lubed your cable recently. That makes a big difference. Yes the pull will be quite a bit stiffer, but it shouldn't bother you once you get to riding it. It is scary to go and ride another quad after the stiffer springs, most others are a lot lighter pull.
Justin
Justin
Zorro
07-22-2001 12:52 PM
