TM 45 users please speak up (have a few ???'s)
Old 07-04-2004, 10:22 AM
SANDMAN430's Avatar
Default TM 45 users please speak up (have a few ???'s)
i live at 3500 ft and the coast where we ride most is 0-25 feet, and sometimes we go as high as 5000 and i never noticed the stock carb being that bad never really did that much changing to be honest.
  #22
Old 07-04-2004, 06:53 PM
MrHorsepower's Avatar
Pro Rider - Oldham Racing
BUILDS THE FASTEST DS's ON THE PLANET!
Want a hot DS, or maybe one of the fastest DS's on the planet? This is the man to contact!
Originally posted by: thebigshow
how is that possible to lose two horse power with a higher compression piston?
If the ring package and cam grind on the skirt are not designed to be used on a NIKISIL cylinder there is no way to increase hp no matter how high the compression.
Been there done that have dyno graphs to prove it.
  #23
Old 07-05-2004, 01:43 PM
thebigshow's Avatar
that would defently suck . more expensive fuel for a slower ride..lol
  #24
Old 07-06-2004, 09:25 AM
sam's Avatar
sam
sam is offline
Roost,
Let me give my 2 cents on the TM45, I got mine used. I took the firmer throttle return spring off and put the softer spring in but first I twisted it to make it stiffer. the pull is great not stiff. I use the acc. pump with a short duration. I love it lots of power over stock. I ported my intake at the same time also. The intake boot between the carb and intake I shaved the lip out so the carb sits flush aganst the intake. I use stock thumb throttle and the aftermarket cable. you can use the stock cable w/ a little mod. I run air box no lid tubes off. Idels great, starts great, runs great. the only thing I need to do is adjust my floats, it likes to leek when I do wheelies.
No matter what you buy us guys will help you with any jetting you need. cost for cost the TM is a good buy. you do get great service w/ the Lectron but at a cost.
I wish they made a FCR 44-45-46 to put on the DS. just a thought.
If you have any more questions just ask
[img]i/expressions/face-icon-small-smile.gif[/img]
Sam
  #25
Old 07-06-2004, 11:23 AM
JEFFROE's Avatar
i just picked up a used 2000 ds. it already had a graydon pipe and ignition. the very first thing i did was throw away the stock carb[img]i/expressions/face-icon-small-tongue.gif[/img] and install a new 45 mikuni w/direct mount filter. cut back the main spring for soft thumb throttle, and rode it for the first time WOW!! this thing runs great. my 760 will be sitting around most the summer now. p.s. i did not touch the tune the new carb, just mounted it, cut the spring back and let drive!!!
  #26
Old 07-06-2004, 02:59 PM
SANDMAN430's Avatar
all the questions on the 45, and really all i can say about it is i'm happy with it.
  #27
Old 07-06-2004, 03:32 PM
biggerisbetter's Avatar
The Mukuni carbs are great carbs for the money. You can go to MOTORCYCLES(parts and accessories) on Ebay and find alot for under 300. ALso I beleive the TM42 is as good or even better on a stock bore(GAS). JMO.
bigger.
bmxatv10
10-14-2022 06:23 PM
Customer Service #1
05-15-2020 08:46 AM
r1pilot83
Utility ATVs
15
11-25-2019 11:39 PM
tysonbully
09-28-2015 02:30 AM
Nosniborpapa
09-12-2015 05:54 PM
Quick Reply: TM 45 users please speak up (have a few ???'s)
