Rider or DS problem?
Old Oct 26, 2004 | 06:13 PM
Prozack's Avatar
Default Rider or DS problem?
The O N L Y way to get good at the drag starts is ...practice.. practice.. and more practice!!
Old Oct 26, 2004 | 06:15 PM
SpinCycle's Avatar
This may sound stupid but check your throttle cable, it may not be opening the carb fully. If there is any slack in the lever adjust it out.
Also pull one of your plugs and look at it, it should be clean but not real white... and as a note after changing my end cap I had to jet down one size on the main. Don't just "try" a jet, read your plug.
Old Oct 26, 2004 | 06:53 PM
Camds650's Avatar
I had to take the End cap off; it was to loud (104 decibels). It did run a lot better with the end cap and a 175 main jet. The plugs look good. The biggest thing is that until 4th gear I can't make up a lot of ground on him. Even with a bad start I was sure that I could walk away for a Z400. I will check the throttle cable when I get home today.
sam Silver lake might be possible for Saturday I will check with the wife and see whats up.
Old Oct 26, 2004 | 09:14 PM
blue250r's Avatar
If you have had the top of the carb of its possible that the diaphram is not sealing correctly if this is the case the carb will struggle to make full throttle, this has happend to me twice when adjusting the needle while at the beach, worth checking your bike should walk all over a z
Old Oct 26, 2004 | 09:43 PM
  #15
sam's Avatar
sam
I ride mostly in the back 10 I have a motocross track I built, check picks for me jumping one of the jumps. you rider moto? been to the mounds many times. thats why I went to the 5"supertrapp I can hush it up any time needed and its a sparky.
you should be at the 170 to 175 main range. check the rubber diaphram as said. If you want to get some 5" disks and end cap I do have one of my first end caps that accept 5" supertrapp disks that I made on the shelf you can have. it will make it ezer to get in to the mounds.
second gear is where you need to be at for starts. I know it wheelies like crazy, but practice leaning over the bars as far as you can at starts as said. your losing speed in first gear starts.
I got stock tire size Klaws, love the 15T . I got a 14 in now that I used for dirt drags I just havent taken it out yet.
Sam
Nondem
Feb 22, 2020 12:20 PM
jrubicon
Where to Ride
Oct 8, 2015 01:05 PM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
hondarider1234
Jul 21, 2015 11:53 PM
SueRockerchick
Jul 20, 2015 07:28 PM
