Jet's for St Anthonys
Old Jun 9, 2005 | 04:51 PM
SJRDKevlar's Avatar
Default Jet's for St Anthonys
Originally posted by: Hightower
stock DS's will run okay with the stock 165 jet, but it will be a little rich. the DS and its big bore vacuum slide carb runs pretty good without changing the jetting, but others like the small dual vac slides on the raptor for example run very poor without jetting changes.
Good rule of thumb is drop one size (2.5 increment) for every 1500 feet you raise.
SJRD you are probably lean now with the power tip and K&N and stock jet, and will probably be right on at the higher altitude and stock 165 jet.
When are you gonna be there? I'll be at St. A's from june 17-22.
Thanks for the good info. We will be at Little Sahaha, Ut from Jun 24-27 and St. A's from June 28 - Jul 2. Hooya!
Lateralus
Dunes and Dune Machines
40
Apr 7, 2003 12:38 PM
Hightower
Jan 24, 2003 01:12 AM
wshrdskin
Jul 17, 2002 05:54 PM
TNTQuadJunkies
21
Jun 29, 2002 08:41 AM
Batoutahell
27
Jun 5, 2002 04:09 PM
