traxter xt
Old Oct 15, 2000 | 04:51 PM
watchdog's Avatar
Is there anyway to get the Traxter XT to shift without a bad crunch. There has to be a way to make it shift smoother.
watchdog
Old Oct 15, 2000 | 06:07 PM
SprintPusher's Avatar
Gee, am wondering how this is happening, must be when your moving the manual gear range lever, low/high/neutral/reverse/park ??
or is this when your pressing a up or down shift button??
Ive been using the Traxter for over a year, only problem was with a poor shifting solenoid when new, dealer replaced it real "speedo" and all is fine. Have heard of shifting into low range and having it jump out, that is a adjustment behind the right front inner liner behind the tire. that solves it Im told.
Good luck
Old Oct 15, 2000 | 06:09 PM
johnc's Avatar
you have to be specific with your prob b4 we can help
JC
Old Oct 15, 2000 | 06:40 PM
watchdog's Avatar
I tried out a new Traxter XT and when up and down shifting it shifted real rough. It made a bad crunch kind of like shifting a standard 5-speed without using the clutch. Is this normal or something out of adjustment.
Old Oct 16, 2000 | 06:31 PM
johnc's Avatar
The shifting mech on a traxter is very rough but it gets smoother as it breaks in. I thought the same things when i test drove one but you will get used to it....JC
Old Oct 16, 2000 | 07:24 PM
Id agree, once you get the feel of the thumb button and the throttle, it will shift real smooth.
Good luck
Old Oct 16, 2000 | 10:04 PM
watchdog's Avatar
The dealer where I test rode the Traxter told me the ES can be adjusted to shift rougher or smoother depending on your liking. Also they now have an auto shift model. I would like to know if this can be adapted to the XT. It would make things easier.
Bkeb
Aug 12, 2015 12:45 PM
tporath
Jul 11, 2015 12:31 PM
K2
Dec 14, 2000 12:45 PM
johnc
Dec 2, 2000 08:07 PM
mudmachine
Aug 5, 2000 01:59 PM
