Lock up style clutch for the DS???
Originally posted by: OregonDunePatrol
Blackhawk,
If you run the Barnett and 60% RWR, that should hold up to 95hp. Where are you at now?
Blackhawk,
Originally posted by: 650VIPER
What makes you think its shot? Slipping? What horsepower? IF a stock clutch with 60% springs can live three years on a 75-80ish hp motor, i'm sure this can last more than 3 rides. Hope its not just out of adjustment.
Donal, alot of people are having good luck with the 9 disk setup and stiffer springs. A few things could be happening with yours; you are getting crazy amount of power out of your setup, running the wrong oil, or don't have it setup with the correct tension.
#15
#16
