Looking for someone to do some work on my DS...
Old Sep 8, 2005 | 02:28 PM
MrHorsepower's Avatar
Pro Rider - Oldham Racing
BUILDS THE FASTEST DS's ON THE PLANET!
Want a hot DS, or maybe one of the fastest DS's on the planet? This is the man to contact!
Default Looking for someone to do some work on my DS...
Originally posted by: mywifesquad
When they replace this plastic washer do they use another plastic one? Or is there a upgrade to brass or something? If it was me I would make a brass or oilite bronze washer.
It has to be plastic because of the neutral safty switch. The plastic breaks contact until the drum is in neutral where a pin sticks through the plastic grounds the switch and turns on the green light on your dash.
I'm not sure why the plastic wads up. We over heated a bike on the circle track big time and melted the washer or at least softened it up alot so when pressure was applied to the shift drum it gave up. I have only seen a couple others do this.
Old Sep 8, 2005 | 02:53 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Thanks MisterHP. That makes sense. I wonder what kind of plastic it is made of? There are some pretty impressive plastics today, but they arent cheap.
Old Sep 9, 2005 | 12:25 AM
TriSum's Avatar
Scoundrel, Yeah I'm sure I could do it, (I'm a mechanic by trade) I just don't have the time. Work, Wife (with Baby on the way), Work and oh did I say Work.
Mr. HP -- "I have only seen a couple others do this." Wow, I'm a member of and elite club. :-)
That sounds like the problem, I lost a coolant hose and it got pretty/REALLY HOT. Also the neutral light would stay on, too bad it has to come apart. Is there anything else I should have John look at that could have gotten hurt/weakened from the heat ??
Thanks for the help. Dave
Old Sep 9, 2005 | 12:38 AM
newbomber's Avatar
my neutral light stays on all the time, could this be my problem?
Old Sep 9, 2005 | 01:23 PM
  #15
222's Avatar
222
I personally would replace it with OEM. It is probably a fail safe thing. If the motor overheats, it fails first and all you have to do is replace it. On the other hand, if it doesn't fail, you'll keep riding until the whole transmission and engine siezes before you know you had a problem.
222
Old Sep 17, 2005 | 05:21 AM
  #16
TriSum's Avatar
Well it seems the pin that MR HP was talking about, the one that comes into contact with drum for the neutral light, got bent. I would recommend to every one to put gauges in, it looks like my thermostat stuck, popped a hose, let all the water out of the motor and it got really hot. The RED light never came on and the fan would shut off, so I didn't know anything was wrong until it was too late.
Thanks for all the help. Dave
hugemoth
Jul 20, 2020 03:28 AM
rcappie4
Jul 18, 2015 07:51 AM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
