stalling????
Old Sep 16, 2005 | 10:28 PM
05dsx's Avatar
Default stalling????
i added a yoshi slip on with the spark arrestor removed and rejetted the carb to 170. the bomb runs good but some times at about 4000 rpms it stalls. seams not to do it in first gear, just all the others. anyone got any idea where to start?
Old Sep 16, 2005 | 10:53 PM
rfwlll's Avatar
Hi there. It sounds like you may be running out of gas. I know this may be difficult to do, but ride it and when it does it shut the gas off as fast as you can "at the pitcock" while letting off the throttle and pulling in the clutch. When you stop loosen your drain screw and see how much fuel comes out. If it seems like very little come out than I would say it is a fuel problem. If thats not the case then I am not sure. Hope this helps you out. RUSS
Old Sep 17, 2005 | 01:05 PM
R00ST's Avatar
does it stumble and bog, or just shut off quickly? Did you adjust the needle at all? You might try raising the needle (lowering the clip) once notch, and seeing if that changes anything.
Pehter
Oct 3, 2024 11:00 PM
QuadRiders
Oct 22, 2015 04:13 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
nastyblaster100
Sep 13, 2015 01:19 PM
