HMF pipe and rear wheel Dyno results for the Outy 800
#21
Originally posted by: cc1999
Like I say the dyno sencing just one cylinder gives a reading that can't be right. Torque is supose to be more than HP, at least on everything I have seen numbers on. If I go by just whatthe dyno showed then it would have 50hp, with only 40lbs of tq. I have seen more than a fiew moters that the Tque is doule or almost, So the nubers the dyno shop gave me seem to be more acutate then cutting them in half. It has allot of power and to think that it had 50 hp but only 40#s of TQ I know can't be right. .
PS: it has nothing to do with dual probes! They just didn't select the correct ignition in their dyno program to read the rpm for a twin cylinder 4 stroke
222
#22
I herd from some sled guys this evening that the wheel dyno can not be used with any kind of acuracy on cvt drive machine. Since the motor revs up imidiatley do to the clutch engagement it holds it and then its all about the clutch. Based on my dyno curve the peak HP rage is held on my twin peakes fom 5 mph to about 55 mph and I am told at that point it starts to drop off because it is blowing through the clutch that I could hold the power up longer by adding more weights to the CVT.
#23
It was 45 hp and now 49 not 59. I need to get a scanner sometime then I could post the graph they gave me, I think next new printer I get will be one of thoses combo / scanner / fax / copy machine kind. But right now I do not have a way to post them.
anyway, i allready got the dyno graph from the HMF website!
