JE 720 components?
Old Dec 31, 2005 | 08:19 PM
  #41
THEBOM's Avatar
THEBOM Racing. If it don't scare you a little, it's not going fast enough !!!
Default JE 720 components?
The piston/bore is 105.5. They are a 12-1. The cylinder bolts in without any mods. The head does have to be clearenced.
I under stand that Pami has had these kits running in their races over there that is equal to our Baja races here.
I have never ran one of these kits on NOS or under boost ????
Old Jan 4, 2006 | 06:50 PM
  #42
ScoobyDFW's Avatar
where can we buy the 105.5mm piston from? do we have to buy a set of 4?
Old Jan 4, 2006 | 06:55 PM
  #43
ERBEDS650's Avatar
JE makes the 105.5 pistons, they told me to go to Mr HP or TVI thats the only guys getting the Hi Compression Pistons custom made.
Old Jan 4, 2006 | 07:02 PM
  #44
THEBOM's Avatar
I had some of the 108mm made and had to buy 4 from JE. CP is going to start making some for me late Jan or early Feb. Depending on how custom of compression you want will depend on how many you have to buy. If it's comon probably just 1, if not ??????
Old Jan 4, 2006 | 08:27 PM
  #45
ScoobyDFW's Avatar
a 105mm piston is listed here for $168: http://www.advantage-on-line.com/Catalog/072-093.pdf
a 105mm piston/sleeve kit is listed here for $349+ sleeve install fee: http://www.nwsleeve.com/cycle.html
Old Jan 4, 2006 | 08:38 PM
  #46
ERBEDS650's Avatar
So who makes the best Sleeve??
125Gdaddy
Sep 14, 2015 02:12 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
John Reed
Sep 9, 2015 03:46 AM
bradco
Aug 21, 2015 08:11 PM
