Has anyone had problems with DS?
Old Nov 4, 2000 | 12:45 PM
amtCHAD's Avatar
Sirchopalot
The DS's are built to last! The reason they are 60lbs. heavier then the raptor is because its built better. The only problem I've had with mine is that if you roll it the headlight breakes real easily. It has plastic mounts. But the ROTAX motor is unbelieviable. The rev-limiter has to go. Ron Wood Racing sells CDI's for $350.. Well worth the money. It will really scream without it. They are simple to put in you just unplug your old and plug in the new one. Its a black box below the left side of the fuel tank. And as far as these so called shootouts? All I've done to my DS is put a Ron Woods CDI and a Graydone Proline pipe on it. I eat Raptors all day long and I wiegh 250lbs. So go figure? The DS is the best!! Right men??
Old Nov 4, 2000 | 01:06 PM
AZRENEGADE's Avatar
Aren't you now running a "modified" DS? Earlier threads in this section established that only stock vs. stock competitions were considered to be valid for new model comparison.
Old Nov 4, 2000 | 02:42 PM
amtCHAD's Avatar
The Raptors that I raced were'nt all stock. Some were piped and geared. Stock ones were no challenge but the modified Raptors kept it close but not close enough. sorry?
Old Nov 4, 2000 | 03:23 PM
DS650DAVE's Avatar
amtCHAD,I have Been thinking about a new exhaust/pipes...But I heard of problems with others.... How do you like the graydon ? Any problems? Did it fit well when you installed it? Does it seal well? Has it discolored?
Old Nov 5, 2000 | 12:13 AM
  #15
amtCHAD's Avatar
Dave, I'm really impressed with the Graydone pipe . It fits well and performes outstanding. 2nd gear wheelies are no problem!! I bought a chrome one for $350. and it has discolored to a yellowish tint (which it doesnt look bad because the bike is yellow) but you can buy a ceramic coated version for $399. Its the same exact pipe. But I am very pleased with it and would recommend to anyone.
Old Nov 5, 2000 | 01:00 PM
  #16
DS650DAVE's Avatar
Chad,thanx for info. on graydon pipe.another question{s};Did you rejet after pipe installed? ,if so what #s?I see you have Ron Woods CDI box from previous posts,Any other motor/performance mods to your DS650?
Old Nov 5, 2000 | 01:40 PM
  #17
AZRENEGADE's Avatar
No reason to be sorry. So, if I follow your logic correctly, my wife on her Banshee, which is modified, eats DS's for snacks and is yet to be beat must be the best bike? Right?
Old Nov 5, 2000 | 09:43 PM
  #18
amtCHAD's Avatar
Dave ,
You do not have to re-jet if you leave your stock air filter on. If you put a K&N on you will have to re-jet. I did not re-jet mine I've ckecked the plugs many times and they are burning great.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
