PISTON
Old Jan 19, 2006 | 08:37 PM
flyinds's Avatar
Default PISTON
crazyds i have friend with a yfz450 he made his own end cap and but the timing a tooth and it ran alot better than stock but my ds with 46hv, race port intake, and end cap i could beat him with about 150lbs mor than him with me and machine.
Old Jan 19, 2006 | 08:39 PM
crazyds's Avatar
Default PISTON
I DO 300 FT DIRT AND WITH THE SETUP I HAVE NOW IM RUNNING IN A CLASS THEY CALL STOCK BUT YOU CAN HAVE PIPES CDI JETKIT 2" BIGGER TIRES AND I TAKE MOST THE STOCKERS
Old Jan 19, 2006 | 09:28 PM
crazypainter's Avatar
Default PISTON
When you run race gas and don't need it you are usually running rich with it because of the slower burn. Probably didn't hardly need to choke it to start either. This is info passed on to me from my tuner when I did the same thing.
Old Jan 19, 2006 | 10:14 PM
crazyds's Avatar
Default PISTON
CRAZY PAINTER,
IS IT BAD TO RUN RACE GAS ON STOCK BORE OR TO SWITCH FROM PUMP TO RACE
Old Jan 19, 2006 | 11:11 PM
  #15
Default PISTON
Will it hurt anything? No. Just your wallet with an unnecassary expense. Your bike runs best with the most volitale burn you can get which is just before detonation. Race gas is a slower burn so its not as hot with the lower compression. My stock comp 03 DS runs 87, my 02 when it had the 11.5 ran 93, 14-1 I ran 110 no issues with detonation good power output. Run the lowest octane you can without pinging for the most power.
Old Jan 20, 2006 | 02:04 AM
  #16
DSNUT's Avatar
Default PISTON
I am not convinced yet about the running rich thing,but that could account for running cooler on racegas. Everything else sounds good to my ears.
Ron
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
