Smoke on decel...where to start?
Old 01-24-2006, 03:55 AM
IdahoVinnie's Avatar
Default Smoke on decel...where to start?
Thanks for the reply Ron.
On car engines, remove sparkplug, and on the compression stroke get the piston EXACTLY on TDC. Into the sparkplug hole, screw in an adapter that connects to an air hose, and apply air pressure. Compress valve spring and remove keepers. Replave seal and re-assemble.
As you stated, I also didn't know if there are clearance problems for a spring compressor.
Old 01-24-2006, 09:07 AM
BUBFRider's Avatar
Does the engine have to come out to take the head off? What about the jug? If I have it down that far, I may ring it as well.
I have a spring compressor and know how to use it, as long as the seals don't have to be pressed in and out, I should be okay.
Where is the best place to get parts?
Old 01-24-2006, 10:48 AM
DSNUT's Avatar
Idaho,
Air pressure sounds like a more practical way. I think I've seen my dad do that before with a home made device.
Bub,
No, disconnect everything off the head then pull the motor mount brackets and bolts in the front and loosen the back motor mount so you can rock the motor down in the front. This will allow the mounting part of the head to slip past the cross member. Have fun with those exhaust header bolts.
Ron
Old 01-24-2006, 10:52 AM
BUBFRider's Avatar
Thanks.
What kind of compression reading should I be getting on a stock motor? I figure I might as well check that before I get too far.
  #15
Old 01-27-2006, 07:01 PM
222's Avatar
222
222 is offline
190psi, but the decompressor has to be disabled...
222
  #16
Old 01-27-2006, 07:43 PM
DSNUT's Avatar
Randall,
Are you referring to the mechanism on the end of the cam? Do you have to remove it to disable it?
Ron
Yamaha_
Utility ATVs
12-16-2022 07:49 PM
DOC HOLIDAY
06-11-2015 12:37 PM
Jbird4681
06-09-2015 01:59 AM
Hondaislife
Sport Quads
05-27-2015 05:38 PM
1000gade
05-27-2015 12:37 PM
Quick Reply: Smoke on decel...where to start?
