Decompressor Help
Old Jan 25, 2006 | 03:02 PM
strictlysand's Avatar
Default Decompressor Help
Thanks a lot all. I was just being careful, but it looks like I need to put a little more muscle behind it. Thanks again.
Old Jan 25, 2006 | 09:18 PM
2BIG2BFAST's Avatar
send me your adress and you can have mine they are all the same rite?
Old Jan 25, 2006 | 09:44 PM
Eaglecollector's Avatar
When you reinstall the decompressor pin in the new cams. You will want everything to move easily. Push the decompressor in and it should spring back freely. If it doesn't. Ya gotta take it apart agian and clean the holes out in the cam itself where the pin goes through. In fact you should be able to slide that pin all the way through the holes in the cam by hand. When you get it like that. Then you can install the decompression mechinism and the pin. It will be almost as tough to install as it was to remove.
Take your time and good luck
bostthehause
May 15, 2012 10:59 PM
busted450r
Jun 27, 2009 07:11 PM
ds650ratrider
Nov 24, 2004 12:06 AM
Cawzican
Dec 27, 2001 09:03 PM
